Serial Number Mismatch When Using DAQmx Property Node
Updated Oct 29, 2018
  • cDAQ-9174
  • NI-9402
I'm using the DAQmx Device Property Node to get the Serial Number of my DAQ Device. When I read the output of the property node, the number I get is different from the Serial Number I have of my device.
The output of the property node is a numerical representation of the device's Serial Number. To get your device's Serial Number you need to convert that number to a hexadecimal representation.
