Code Generation Tab Missing From Simulink
Updated Oct 3, 2018
  • VeriStand
  • LabVIEW Model Interface Toolkit for VeriStand
I am attempting to create a Simulink model for use in VeriStand. I cannot find the Code Generation tab, it is missing.
You may not have the sufficient add-ins installed in MathWorks software to perform compilation (e.g. Simulink® Coder). See Compiling a Model from The MathWorks, Inc. Simulink® Software and Setting up The Mathworks, Inc. MATLAB® to Create a VeriStand or Model Interface Toolkit Compatible DLL for the required software.
There may be additional issues with software set-up:
1. Version incompatibility between the required software components.
2. Model support not installed for VeriStand.
