Only Half of Waveform Is Generated When Using Python NI-FGEN
Updated Dec 6, 2018
  • PXIe-5451
  • NI-FGEN
Programming Language
  • Python
I am using the nifgen module for python. When I output the waveform on one channel, I am only getting half of the waveform. Why is this?
This is because of the note in create_waveform_numpy. If you don't specify a channel that it will split you data across all channels. So instead of doing session.create_waveform(waveform_data_array), specify the channel and do session.channels[0].create_waveform(waveform_data_array).
