Error 1097 When Creating an Installer in LabVIEW
Updated Apr 20, 2023
I have an application in LabVIEW and I am trying to create an installer using the Application Builder. But, I getting the error 1097:
Error 1097 occurred at Call Library Function Node in NI_MDF.lvlib:MDFProdInfoList_Close.vi->CDK_DistParts_GetInstalledProducts_CORE.vi->CDK_DistParts_GetInstalledProducts.vi->IB_MSI.lvclass:Create_Default_DistParts.vi->IB_MSI.lvclass:Create_New_Installer.vi->AB_UI_Frmwk_Installer.lvclass:Initialize.vi->AB_UI_Initialize_Framework.vi->AB_UI_FRAMEWORK.vi->AB_CreateNewWizard_Invoke_CORE.vi->CDK_CreateNewWizard_Invoke.vi->CDK_CreateNewWizard_Invoke.vi.ProxyCaller
How can I solve this issue?
This problem is due to a software corruption, to solve this try one of these methods to uninstall and reinstall LabVIEW and LabVIEW Application Builder, if one doesn't work, another may.
If you are getting this error using a Dynamic Link Library (dll) please refer to Error 1097 While Calling DLL with Correct Calling Convention .
