LabVIEW Slowdown When Using Configuration File VIs
Updated Oct 1, 2018
I have a VI I've created that uses the Configuration File VIs. When I run that VI, it takes a long time (10 seconds sometimes) to finish execution. What can I do to speed this VI up?
Ensure that you do not have any extraneous data in the configuration file being read that you do not need. If the configuration file is extremely large (500kb for example) then it will take longer for the Configuration File VIs to process it.
