Using NULL Values or Pointers in LabVIEW
Updated Jan 13, 2020
I want to call a .NET DLL that requires that a NULL value as an input. Is there a way that I can create a NULL value in LabVIEW?
There is no way to explicitly create a NULL value in LabVIEW that you can pass into a DLL. Some workarounds for this are:
  1. Within LabVIEW, configure the input parameter that you want to pass a NULL value to as a numeric passed by value. Pass a value of 0 into this input on the block diagram. Many, but not all DLLs will treat this as a NULL value.
  2. Create a wrapper DLL to handle NULL pointers/values outside of LabVIEW.
LabVIEW is a strongly typed language, meaning that all data must have a type defined for it before runtime. As a NULL value has no data type (Void), it can therefore not be used in the LabVIEW environment.
