Can I Use cRIO to Perform HIL Tests?
Updated Oct 30, 2018
  • cRIO-9049
I have a cRIO, I am not sure if I can use it to perform Hardware in the Loop test.
For HIL tests you need user interface, real time processor and I/O modules. The cRIO has a real time processor therefore it can be used for the test. C series modules can be used for I/O operations.
The speed needed for the cRIO will depend on the speed requirement of the application. For the best product recommendation please contact NI Sales Department.
