Internal Software Error 7 When Compiling FPGA Code
Updated Oct 17, 2022
  • LabVIEW FPGA Module
  • Compile Cloud Service
  • FPGA Xilinx Compilation Tools
When compiling my FPGA program I am getting the following error:
LabVIEW FPGA: An internal software error in LabVIEW FPGA Module has occurred.
Error 7 occurred at Read from Text File in
This happens regardless if I do a local compilation or use the Cloud Compilation Service. Why is this occurring and how do I get rid of these error messages?
The FPGA compilation can be affected by a previous compilation attempt that became corrupt. To solve this issue we need to clear the corrupt files from the computer.
  1. ​Navigate to C:\NIFPGA
  2. Open the compilation and jobs folders
  3. ​In each folder, you need to remove the folders associated with the corrupt FPGA compilation attempt.
    • ​​The corrupt folder may share the same name as the VI you are trying to compile.
  4. ​Reattempt the compilation
If this error shows up at the first attempt to compile the FPGA, then the solution will be to remove and install LabVIEW and all required packages.
