Configuring a Dynamic Dispatch VI in LabVIEW
Updated Aug 31, 2026
In this article, you will configure dynamic dispatch in LabVIEW to allow a child class to override a parent class method and resolve related class inheritance and VI configuration issues. By completing this procedure, you will successfully link a child class to a parent class, enable dynamic dispatch behavior, and eliminate errors such as attempting to override a static VI without a dynamic dispatch terminal. This task requires LabVIEW Development System (version 2009 or later with LabVIEW Object-Oriented Programming support).
To implement Dynamic Dispatch, ensure that the child class is correctly inherited by the parent class:
1.- Right click the child class and click the Properties option.
2.- Go to the inheritance category and select Change Inheritance...
3.- Select the parent class to inherit and click Inherit from Selected.
4.- Click OK to exit the properties dialog.
5.- Right click the parent class and click New >> VI From Dynamic Dispatch Template...
6.- Implement the functionality of the parent class method in case it should have any.
7.- Make sure all VIs and classes are saved to disk.
8.- Right click the child class and click New>>VI for Override...
9.- Implement the functionality for the overriding method.
Next Steps
