In this article, you will configure dynamic dispatch in LabVIEW to allow a child class to override a parent class method and resolve related class inheritance and VI configuration issues. By completing this procedure, you will successfully link a child class to a parent class, enable dynamic dispatch behavior, and eliminate errors such as attempting to override a static VI without a dynamic dispatch terminal. This task requires LabVIEW Development System (version 2009 or later with LabVIEW Object-Oriented Programming support).
