Access System Information on Linux RT CompactRIO Target Using Console Out
Updated Oct 8, 2018
  • CompactRIO Chassis
  • NI CompactRIO
  • NI Linux Real-Time
I want to access the system information (Model, Serial Number, Firmware Version) of my Linux RT CompactRIO using only the Console Out.
Information regarding the system of a CompactRIO are usually found in NI Measurement & Automation Explorer or programmatically using the NI System Configuration API with LabVIEW for example.
There is a command line in the Console Out of a CompactRIO that allows you to access basic system configuration using the same NI System Configuration API.
By typing the following command: lsni -v, the device will scan for available System Configuration API resources and display information such as adapters, model name and serial number:
For more information regarding the software, operating system and name of the device, you can use a more generic Linux command line that displays these information in detail. The command in this case would be uname -a:
You can do more with each of these commands, just type in command -help to see all the available options for each utility.
