Why "Result Processing" or "Model Options" are Not Visible In Configure In TestStand
Updated Jan 16, 2019
  • TestStand
In the TestStand Configure Menu, I cannot see the sub-menu "Result Processing" or "Model Options".
These two sub-menus options are managed by the process model. If you don't see it:
  • Go to Configure-->Station Options
  • Select Model tab
  • Select "Use Station Model"
