I2C communication requires the device to tri-state the DIO lines on the fly. The NI-9401 is unable to do this without external hardware. NI thus recommends the NI-9402 for I2C communication.
This library is installed using VIPM. If you are using LabVIEW 2010 or later, ensure to disable Mass Compile before installing the driver. Otherwise, a broken VI will appear in the library VIs.
Complete the following steps to disable Mass Compile:
- Open VI Package Manager.
- Select Tools and then Options.
- Remove the checkmark from the Mass Compile VIs After Package Installation checkbox.
Note: Support for this product is provided on the NI Developer Forums at forums.ni.com.
