You can use the TestStand API StationOptions property
BreakpointsEnabled to enable and disable all breakpoints in a test station. You can either use the
ActiveX/COM step in your sequence or an Expression.
With the
ActiveX/COM step, use the following configuration:
With the Expression you can input the following: RunState.Engine.StationOptions.BreakpointsEnabled
You can set this expression to either True or False depending on whether you would like your breakpoints enabled or disabled, respectively. The breakpoints will not be deleted, but TestStand will indicate that they are disabled by turning the breakpoint icons clear.
