Recover Access to TestStand™ After a Forgotten Password
Updated Oct 20, 2026
  • TestStand
I need to log into TestStand, but I forgot my password. Can I retrieve my password or otherwise gain access to my account?
No. Once a password has been set, it cannot be retrieved. Before TestStand saves a password to the Users.ini file located in <TestStand>\Cfg, the password is encrypted.
If a password has been forgotten or is no longer needed, the available recovery options depend on the version of TestStand being used.
TestStand 3.5 and Earlier
For TestStand 3.5 and earlier, open the Users.ini file with a text editor.
User entries in the Users.ini file will have a tag of the form [UserLists.Users[ X ]] where X is the index of the user in the user list. Immediately below the tag, the file may contain fields such as LoginName, Password, FullName, and %COMMENT. For example:
[UserLists.Users[1]]
LoginName = "joe" Password = "R3GVMF6NG7;242oFg:GJjl" FullName = "Joe NI" %COMMENT = "nice guy"
If a user section does not contain a Password field, that user does not have a password configured and can log in by specifying only the username.
To create or modify a password for a user, use the User Manager in TestStand.
TestStand 4.0 and Later
For TestStand 4.0 and later, the Users.ini file contains binary data and cannot be meaningfully interpreted or edited with a standard text editor.
If the Administrator password has been lost, or if all user passwords need to be reset, rename or delete the Users.ini file. The next time TestStand launches, it creates a new Users.ini file containing only the default Administrator account with a blank password.
The recommended method for managing user passwords is to log in using an account with user management privileges and make changes through the User Manager.
At least one user with user management permissions must exist to manage users through the TestStand Sequence Editor. An Administrator can create, modify, or remove passwords for other users.
If the Administrator password is unavailable and no account with user management privileges can be accessed, modify or replace the Users.ini file using the procedure appropriate for the installed version of TestStand.
