Unknown Error <ERR> When Building Installer or Application
Updated May 20, 2019
When trying to build an installer for my program I get the following message:
CodeSignAPI.lvlib:Get Signing Error String.vi<ERR>
Error: The Timestamp Authority URL specified does not point to a valid Timestamp Authority server, or an unknown error occurred.
<b>Complete call chain:</b>
CodeSignAPI.lvlib:Sign with Certificate.vi
IB_MSI.lvclass:Sign_Setup.vi
IB_MSI.lvclass:Build.vi
CDK_Engine_Main.vi
CDK_Build_Invoke.vi
CDK_Build_Invoke.vi.ProxyCaller
The installer was able to build before, what could be causing this issue?
Under 'Application Properties' in the Application Builder navigate to 'Windows Security' and uncheck 'Apply Digital Signature'. This property is not selected by default.
If you require a digital signature, ensure that you're following the steps listed in User Account Control, Digital Signing, and Manifests in LabVIEW Built Applications.
