Synchronisation of Two USB-6343 Modules
Updated Jan 3, 2019
  • USB-6343
I am using two separate USB-6343 modules to perform analog voltage measurements. How can I synchronize those measurements?
The only way to synchronize measurement performed by two USB-6343 modules is to do it in hardware. You have to connect PFI ports of those modules by wire and configure them properly. In the first USB module, PFI should act as a triggering signal generator and in the second one as an external triggering signal input.
