NI-RFSG Driver Support for LabVIEW Missing Error
Updated Nov 19, 2018
  • LabVIEW 2018
  • NI-RFSG
  • NI-RFSG 18.1
When loading up a project in LabVIEW I run into the following error:
NI-RFSG Driver support for LabVIEW 2018 is missing and is referenced by the following VIs
Where could I obtain the correct driver to solve this issue?
In order to have NI-RFSG driver support for LabVIEW, you will need to download a version number of NI-RFSG that matches or exceeds the version number of LabVIEW you are using.
As an example, if you are trying to use NI-RFSG in LabVIEW 2018 then you will need at least NI-RFSG version 18.0 or higher.
