Routing Counter Output to Two Digital Outputs
Updated Jan 3, 2019
  • cDAQ-9174
Is it possible to route the output signal of one counter to two independent digital outputs in cDAQ-9174?
It is not possible to set such routing inside the cDAQ-9174 . The connections have to be done in strict 1 to 1 relation (1 Counter output - 1 Digital Output). The only solution in this situation is to physically wire those signals outside the chassis.
The possibilities of routing the signals inside the chassis are device-dependant. For a specific application check relevant datasheet document.
