Thermocouple Measurement with USB-6002 and a Cold Junction Compensation Source
Updated May 22, 2025
  • USB-6002
Other
  • Thermocouple
I'm trying to use a K type thermocouple with the USB-6002, and it requires a Cold Junction Compensation source. Does the USB-6002 have built-in cold-junction compensation? How can I add a cold-junction compensation source to it?
The USB-6002 does not have built-in cold-junction compensation.
Here's an easy way to set up cold-junction compensation in NI MAX if you have a second thermocouple:
  • Create a task for temperature
  • Choose one channel thermocouple input to be your cold-junction measurement
  • Set the CJC (cold-junction compensation) source to Constant
  • Add your measurement channel(s)
  • Set the CJC source of your measurement channel(s) to Channel and select the channel used in your cold-junction measurement channel
