DAQ Exception: Source Terminal to Be Routed Could Not Be Found on the Device
Updated Sep 25, 2018
  • USB-6211
Programming Language
  • C# .NET
I am running into the following error when trying to write data through my DAQ device in C# .NET.
This error usually occurs when the sample clock is not configured correctly. Check to see if you have configured your sample clock correctly. You can find details about configuring the sample clock on the ConfigureSampleClock Method Page.
