Setting up IEPE Open/Short Detection in LabVIEW
Updated Jul 10, 2026
  • Sound and Vibration Device
  • PXI Sound and Vibration Module
  • C Series Sound and Vibration Input Device
  • Sound and Vibration Input Device for FieldDAQ
How do I set up Open/Short detection for my IEPE sensor in LabVIEW?
You can use a DAQmx Read Property Node to detect overcurrent or an open channel in your device using the properties below.
Shorted Channels
Open Channel
The snippet below shows the implementation in an IEPE Accelerometer Task.
Refer to Overcurrent Detection and Open Current Loop Detection  in the NI-DAQmx manual for additional information.
Refer to your device's documentation to verify it supports Open / Short detection.
