What Happens If the Wire to the NI 9265 Module Is Disconnected?
Updated Sep 18, 2018
  • NI-9265
What will happen to the output of the NI 9265 module if I disconnect the signal wire, while it is powered on?
NI 9265 has built-in open-loop detection, which generates an interrupt in software when an open loop is detected as well as zeroing outputs to ensure safety and avoid driving actuators at system power on.
