In LabVIEW, this can be done by using the niSwitch Get Relay Position VI. The output of this VI will be Open or Closed depending on the switch name you specify. Note: The niSwitch Get Relay Position VI requires the name of the switch. You can take advantage of the Number of Relays property and the niSwitch Get Relay Name VI to find the names programmatically.
Alternatively, you can run the NI-Switch Soft Front Panel while the switch is being used to read the current state of the switches.
Note: The switch state cannot be read in Scanning Mode.
