I am using the TestStand simple user interface example which located in the following directory: <TestStand Public>\UserInterfaces\Simple\LabVIEW\TestExec.llb\Top-Level VI.vi. When running this example it will show all three steps(Setup, Main, and Cleanup). However, I don't need to show the Setup and Cleanup steps. Is it possible to show only the Main step when executing?
