My TEDS Device Is Returning Incorrect Values In DAQExpress
Updated Jan 16, 2019
  • DAQExpress
  • My TEDS sensor returns proper values in MAX but not in DAQExpress.
  • DAQExpress displays the wrong value from my sensor.
TEDS tasks are not currently supported in DAQExpress. Setting up a linear scale based of the sensitivity of the device is a valid alternative. Setting a custom linear scale can be done by adjusting the parameters on the Channel Properties bar of the task in DAQExpress.
Another alternative is to set up the TEDS task in LabVIEW.
