LabVIEW Type Cast Output is HEX Instead of Decimal
Updated Sep 11, 2018
  • LabVIEW 2018
I am using the LabVIEW Type Cast function to change my string to a U8. I want a decimal value but am only seeing hexadecimal. How can I resolve this?
Your indicator is probably configured to display hexadecimal values. To change this, Right-Click Indicator >> Display Format... >> Select 'Decimal' >> OK. Your values should now display as expected.
