.lvtest Files Not Working After Moving Files on Disk
Updated Sep 12, 2018
  • LabVIEW Unit Test Framework Toolkit
I am using Unit Test Framework Toolkit in LabVIEW, and I have moved the .lvtest files in Windows explorer. When I open the file in the project explorer, the file is blank/unresponsive.
If you know the location of the .lvtest file on your computer, you can re-link it to the corresponding VI by following these steps:
1. Open your LabVIEW Project Explorer.
2. Right-click the .lvtest file and select "Remove from Project"
3. Right-click the corresponding .vi file and select Unit Tests > Add Test from File.
4. Browse for the matching .lvtest file and hit OK.
