I Get Error Code -363357: Sample Rate Not Being Constant
Updated Nov 22, 2018
  • LabVIEW Electrical Power Toolkit
I have a VI running in the CompactRIO RT with VIs from the electrical Power toolkit. I want to perform several types of analysis such as torque, load, and efficiency but I get error code 363357 "sample rate not being constant". Why is this?
Using the wrong architecture and having all the Electrical Power Toolkit VIs in the same loop can lead to resampling. Unnecessary resampling of motor-related VIs can cause error 363357.
For example, If you need to analyze torque and load with the "Motor VIs" & efficiency with the "Power Measurement VIs", you may use the following architecture:
