Add File to Existing LLB
Updated Nov 29, 2023
I have an existing LLB (library file) already created. How do I add new files (VIs) into it?
Drag and drop into the LLB Manager to add new VIs to it.
An alternate method is to use File >> Save As... from the VI to save directly into the LLB.
LLBs are harder to use with source control and corruption is often a more serious issue within them and can lead to corruption of the entire library. Explore LabVIEW Project Libraries as an alternative: Converting an LLB to a Project Library.
