Synchronized XNET Frames not Sent with Proper Timing
Updated Sep 6, 2018
  • NI-XNET
I am using XNET and I would like to send 4 Frames with an offset of 10ms. When I send the frames with this offset, they are not received by the XNET Start VI with that offset (anywhere from 20ms to 30ms). What can I do to make sure that messages are received with the timing I desire?
In order to use the XNET Start VI, you'll need to use a property node connected to the XNET session and set AutoStart to false (shown below)
