Scales Missing on NI MAX
Updated Oct 12, 2018
When I open NI MAX I do not see the scales under the drop down menu like I saw on the examples.
If you don't have DAQmx installed on the computer you are currently using, you will not be able to see the scale.
Download a compatible version of DAQmx and you will be able to see the scale as one of the options under the drop down menu.
