Error -2147220719 Occurred at DAQmx Create Channel
Updated Mar 20, 2023
I am getting the following error when I am running my LabVIEW code with my DAQmx functions:
Error -2147220719 occurred at DAQmx Create Channel (AI-Voltage-Basic).vi:1780001
Possible reason(s):
MAX: (Hex 0x80040311) The client process has been disconnected from the configuration server. If this problem persists, please note the steps you performed that led to this error and contact technical support at http://ni.com/support.
Task Name: _unnamedTask<0>
This error indicates that NI MAX cannot access the configuration settings for connected DAQ devices. When this error occurs you will also see that when you open up NI MAX and click on Devices and Interfaces you will notice that NI MAX will give you an error stating:
MAX Database Connection Error:
There was a problem connecting to the database.
Please restart your computer and contact National Instruments if the problem persists.
Once this error message comes up refer to Database Connection Error in Measurement & Automation Explorer (NI MAX) to continue troubleshooting.
This error can also be from not having the correct device being called in your LabVIEW code so ensure devices in the LabVIEW code match what is under Devices and Interfaces in NI MAX.
