While I'm Trying To Launch A Sequence From Remote I Have To Reload Code Module
Updated Sep 18, 2018
  • TestStand
I am trying to launch a sequence which initially was located on a remote computer and when is copied from the remote computer to local computer I always need to reload the code module while TestStand cannot find the right path.
If the sequence file has a script (for instance a file .bat), you need to copy also the script otherway it will be runned from remote and there will be more security check from the OS which probably will cause an unload of the code modules. You can solve the problem by moving the script file from on the local computer.
