問題敘述
我試圖在LabVIEW中呼叫共享庫(例如DLL),但無法正常工作。當我嘗試使用 Import Shared Library 嚮導匯入它時,它顯示以下訊息:
Undefined symbols can prevent the wizard from recognizing functions and parameters. To correct this problem, check the header file to determine if you must add predefined symbols. Click the Back button to return to the previous page of the wizard to add a preprocessor definitions.
即使我定義了所有符號。哪裡出錯了?
