Can I Use the LabVIEW OPC UA Toolkit with Measurement Studio?
Updated Aug 31, 2018
  • Measurement Studio
  • LabVIEW OPC UA Toolkit
I have a series of machines running C# applications that monitor and publish process parameters. I would like to set up an OPC UA server using Measurement Studio to host these parameters and while utilizing my C# code.
Is it possible to use the LabVIEW OPC UA Toolkit in Measurement Studio?
It is not possible to use the OPC UA Toolkit in Measurement Studio as the OPC UA Toolkit does not have .NET support.
Consider using the Measurement Studio Network Variable .NET Library for transfer data between applications over a network.
