Can I Search for the Indicator or Control Names Selected on Read/Write Control Function?
Updated Sep 26, 2018
  • LabVIEW FPGA Module
I want to search for all the Read/Write Control functions on block diagram that read a value from a specific indicator in the FPGA VI or write a value to a specific control in the FPGA VI. I tried to do this using Edit>>Find and Replace, but they were not found in the search result. Is there any way to search for the Read/Write Control functions by a selected indicator or control name?
No, you cannot search for Read/Write Control functions by the name of the selected indicator or control.
One workaround is to add a label with the name of the selected indicator or control. You can label the wire connected to the Read/Write Control node or label the node itself.
