Suppressing Automatic Reboot after Software Installation
Updated Aug 30, 2018
Other
  • all NI software
I programmed a batch script to install NI software packages automatically on several computers:
T:\LV\setup1.exe /applyspecfile T:\LV\spec1 /q /acceptlicenses yes
T:\LV\setup2.exe /applyspecfile T:\LV\spec2 /q /acceptlicenses yes
T:\TS\setup.exe /applyspecfile T:\TS\spec /q /acceptlicenses yes
However, after the first installation is executed the computers automatically reboot. The lines after this point never run due to the reboot. Is there a switch that I can use to prevent this?
There is a command line option to prevent automatic rebooting. It is /r respectively /r:n
NI installers have many command line options that change the installers' behavior. Execute setup.exe /h on the command line to get a window showing a full list like this:
