Configuring sbRIO-9651 DIO as Open Collector
Updated Aug 29, 2018
  • sbRIO-9651
  • LabVIEW FPGA Module
How can I configure the sbRIO-9651 DIO to be Open-Drain (Open Collector/Sinking)?
You can use the Output Enable in LabVIEW to force the DIO into tristate. To set the pin as Open-Drain, set Output Enable to False to float to a tristate voltage.
