Can I Run a Bitfile Made For One cRIO Model on a Different cRIO Model?
Updated Aug 29, 2018
  • NI-9144
  • NI-9145
  • CompactRIO Chassis
  • LabVIEW FPGA Module
I have a .lvbitx file that I generated for one type of cRIO (ex. NI-9144) and would like to deploy the same code to another model of cRIO (ex. NI-9145). Can I do this?
No, you must recompile the bitfile for each different device model that you are deploying to as the architecture of the device changes between different cRIO models.
