Archived:Running updateNIDrivers Fails and Returns NI-KAL Errors After Linux Kernel Update
Updated May 16, 2019
National Instruments does not actively maintain this document.
  • Linux
I've just updated my Linux kernel and went to update my NI device drivers by running /usr/local/bin/updateNIDrivers but the command fails and returns the following:
Configuring NI-KAL for kernel version 3.10.0-862.el7.x86_64...
Building module nikal...
nikal: CC [M] /var/lib/nikal/3.10.0-862.el7.x86_64/nikal/nikal.o
nikal: /var/lib/nikal/3.10.0-862.el7.x86_64/nikal/nikal.c:2043:10: error: GENL_ID_GENERATE undeclared here (not in a function)
nikal: ERROR: failed to build nikal
nikal: ERROR: NI-KAL update failed.
nikal: ERROR: make of nikal kernel module failed, not installing kernel module.
nikal: ERROR: updateNIDrivers should be called again after fixing the problem.
nikal: ERROR: Update of National Instruments drivers failed.
This document only applies to versions of NI software released prior to NI Linux Device Drivers. For new designs, NI recommends using NI Linux Device Drivers to take advantage of repository-based installation and more frequent updates to support.
​​​​​​​This issue is caused by an incompatibility between the National Instruments Kernal Abstraction Layer (NI-KAL) and version 3.10.0-862.el7.x86_64 of the Linux kernel. This issue can be solved in one of two ways:
  1. The preferred solution would be that you update all of your NI device drivers to version 18.0 or later. NOTE: this requires uninstalling all NI device drivers prior to version 18.0.
  2. If you are unable to update your NI device drivers to 18.0 or later, updating NI-KAL to the most recent 17.5.X version should also resolve the issue.
