Error about GCC when building *.so or *.lvmodelso from LabVIEW Project
Updated Jun 5, 2026
  • VeriStand
  • NI Linux Real-Time
  • When I try to build a Shared Library (.so) for a NI Linux RT Target within my LabVIEW Project, I receive an error that says GNU Compiler Collection (GCC) is not installed.
  • I am trying to generate a VeriStand Model for my NI Linux RT target (*.lvmodelso) from a VI in LabVIEW, but it get an error message.
In order to build a Shared Library of a LV Model from the LabVIEW Project for a target running NI Linux RT, you must have the appropriate version of the C/C++ Development Tools for NI Linux Real-Time installed as referenced by the charts below.
Correct Version of C/C++ Development Tools for LabVIEW-Generated .so Files
LabVIEW Version for .so FilesCorrect Version of C/C++ Development Tools
2014-2016Eclipse Edition 2014-2016
2017 and laterEclipse Edition 2017
Correct Version of C/C++ Development Tools for LabVIEW-Generated VeriStand Models
VeriStand Version for LabVIEW-Generated ModelsCorrect Version of C/C++ Development Tools
2017 and earlierEclipse Edition 2014-2016
2018 and laterEclipse Edition 2017
How to Manually Install the C/C++ Development Tools
You can download and install the C/C++ Development Tools Download - NI from the NI web site.
If you need the Eclipse Edition 2014-2016, please reach out to Technical Support by creating a Service Request.
For reference, the full software stack needed and the order of installation is the following:
  1. LabVIEW
  2. LabVIEW Real-Time Module
  3. LabVIEW FPGA Module
  4. VeriStand (matching year with LabVIEW)
  5. CompactRIO Drivers
  6. C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition
