How to Use the quotient(x) Function in VeriStand?
Updated Aug 29, 2018
  • VeriStand
I want to divide two numbers in a VeriStand Real-Time Sequence. I found the quotient(x) function on VeriStand's help, however I am not sure how to use it.
This is a known issue in older versions of VeriStand's help file. The parameter "y" is missing, it should read quotient(x,y) instead. The automatic popup-help in VeriStand's Expression Editor shows the correct parameters.
