I Can Not Detect my cDAQ 9172 with NI DAQmx 17.5 on LabVIEW NXG 2.1?
Updated Oct 18, 2018
  • cDAQ-9172
  • LabVIEW NXG
  • NI-DAQmx 17.5
I want to use my cDAQ 9172 on LabVIEW NXG 2.1 but I can't see it on the System Designer. I checked the compatibilities :
  • I saw the driver NI DAQmx version 17.5 is the minimum required for LabVIEW NXG 2.1.
  • NI DAQmx 17.5 is also the last version which support the cDAQ 9172.
Everything seems compatible but I can not see my device on the System Designer of LabVIEW NXG. What can I do to detect my cDAQ 9172 ?
Effectively, the cDAQ 9172 is compatible with the driver NI DAQmx version 17.5 and this driver is compatible with LabVIEW NXG 2.1. On the NI-DAQmx 17.5 Readme, at LabVIEW NXG Support and Considerations chapter, there is the list of the non-supported hardware on LabVIEW NXG. The NI cDAQ 9172 is in this list so unfortunately, it is not possible to use it on LabVIEW NXG.
