Oscilloscope Readings Are Half Than Generated Signal
Updated Jan 7, 2019
  • PXIe-5171
When reading data from an PXI Oscilloscope the data are exactly half than the values from a functional generator.
  • Check the input impedance of the oscilloscope and output impedance of a functional generator.
  • Check impedance compensation on a functional generator.
If you have 50Ω input impedance and 50Ω load impedance the readings on a oscilloscope are half because these impedances acts as 1:1 voltage divider.
