Why I See My PXIe-5413/5423/5433 As FPGA Target on NI MAX?
Updated Sep 4, 2018
  • PXIe-5433
  • PXIe-5423
  • PXIe-5413
  • NI-FGEN
I have a PXIe-5413/5423/5433 on a PXI chassis and on NI MAX I see the board as a FPGA target, but those board doesn't have a open FPGA programmable, how is it possible?
This is a known issue of the NI-FGEN driver from the 17.1 version. You can check the pinout features from the manual and you can use the NI-FGEN Soft Front Panel instead of the NI-MAX Front Panel.
