Is It Possible To Expand PXIe-2527?
Updated Sep 3, 2018
  • PXIe-2527
  • PXI-2527
  • Switch Executive
  • NI-SWITCH
I have more than 1 NI PXIe-2527 and I need to merge those to have a larger multiplexer: for instance the NI PXIe-2527 can be configured as a 64x1 multiplexer and by merging 2 of those I could create a 128x1 multiplexer. How can I do it?
Normally this is possible by shortcircuiting the COM output of the boards on the terminal block. For example in the case of the NI PXIe-2527 the connector block (NI TB-2627) provide a connector that facilitate the connection:
For instance if you need to connect 2 Switch, you have to connect the COM0+ with the COM0+ of the other Switch and the same for the COM0-.
