Support for X Series DAQ Cards in Linux
Updated Aug 27, 2018
  • PCIe-6351
I'm planning to use a PCIe-6351 card on a Linux Machine. I wanted to check the compatibility for X Series cards in Linux distributions.
Commonly, the driver used for DAQ devices on Linux machines was NI-DAQmx Base. The X Series cards are not supported even in the latest version (NI DAQmx Base 15.0).
On the other hand, with the new release of the NI Linux Device Drivers (July 2018), the support for X Series DAQ cards was added. Please review the table below to check the compatibility of your device.
In the device support table above the "X" indicates that the device is supported, and "-" indicates that the device either does not exist or is not supported in NI-DAQmx.
