Disable DACs or ADCs on USB DAQ Device to Reduce Power Consumption
Updated Dec 31, 2018
  • USB-6366
  • USB-6356
I would like to know if it is posible to disable the ADCs (Analog-Digital Converters) and the DACs (Digital-Analog Converters) of my USB DAQ Device to reduce the power consumption specification.
These resources are not user-accessible and can't be disabled. You need to provide the power specified in the datasheet for it to work properly. If you want to be able to control the power consumption, you should consider using a cDAQ device.
