Although some Ettus USRPs can be used with NI software, not all Ettus branded USRPs are supported by LabVIEW, LabVIEW FPGA, or the NI-USRP driver. You can verify the compatibility of specific versions of
NI-USRP driver and the Ettus Branded USRPs in the respective readme document. Below is a list of the Ettus products which are supported by NI software:
- Ettus Research USRP2
- Ettus Research N200
- Ettus Research N210
- Ettus Research X300
- Ettus Research X310
Above devices are supported if using any of the following daughterboards:
- TwinRX
- UBX
- CBX
- CBX-120
- WBX
- WBX-120
- SBX
- SBX-120
- XCVR2450
For fully integrated and single-board Ettus Research B200/B210 see additional information.
If you are using one of these products, you can update the firmware and FPGA images to use the NI-USRP driver or you can use LabVIEW FPGA if the device has a user programmable FPGA.
